10 years agointerface a module with avalon bus
Good evening; i want to know how to interface a module HDL with the avalon bus if any one can answer me Thank you
10 years agothis is the code iam trying to use
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; ENTITY adder_avalon_interface IS PORT ( --clocks and resets clock, resetn : IN STD_LOGIC; --Avalon MM slave port (for nios) avs_s0_read : IN STD_LOGIC; avs_s0_write : IN STD_LOGIC; avs_S0_cs : IN STD_LOGIC; avs_s0_writedata: IN STD_LOGIC_VECTOR(7 DOWNTO 0); avs_s0_readdata : OUT STD_LOGIC_VECTOR(7 DOWNTO 0); avs_s0_address : IN STD_LOGIC_VECTOR(1 DOWNTO 0) ); END adder_avalon_interface; ARCHITECTURE Structure OF adder_avalon_interface IS SIGNAL to_adder, from_adder : STD_LOGIC_VECTOR(7 DOWNTO 0); COMPONENT adder PORT ( clock, resetn : IN STD_LOGIC; A : IN STD_LOGIC_VECTOR(7 DOWNTO 0); B : IN STD_LOGIC_VECTOR(7 DOWNTO 0); S : OUT STD_LOGIC_VECTOR(7 DOWNTO 0); C : OUT STD_LOGIC ); END COMPONENT; BEGIN to_adder <= writedata; --WITH (chipselect AND write) SELECT adder_instance: adder PORT MAP (clock, resetn, to_adder, from_adder); readdata <= from_adder; END Structure; For the adder here is the code: library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; entity ADDER is generic(n: natural :=8); port( A: in std_logic_vector(n-1 downto 0); B: in std_logic_vector(n-1 downto 0); clock, resetn: in std_logic; carry: out std_logic; sum: out std_logic_vector(n-1 downto 0) ); end ADDER; architecture behavioral of ADDER is -- define a temparary signal to store the result signal result: std_logic_vector(n downto 0); begin process begin -- the 9th bit should be carry WAIT UNTIL clock'EVENT AND clock = '1'; if resetn = '0'THEN result <= "000000000"; else result <= ('0' & A)+('0' & B ); end if; end process; sum <= result(n-1 downto 0); carry <= result(n); end behavioral; yhanks for advance
