Intel Stratix 10 GX Ethernet Hard IP
- 4 years ago
Hi Aravind,
Apologize but I couldn't give a confirmed answer on your query as its out of my expertise. But I would suggest that it will better to re-evaluate the board design again. I guess even though its 0.09V voltage change, it might have some impact.
You may need to discuss with your board designer to determine if it still meet the spec since the datarate also become faster.
Pavee
Hi Aravind,
Pavee
Hi Pavee,
Thank you for your answers, it helped me a lot!
We are planning to use E-tile itself
Thanks & regards,
Aravind D
- AK-14 years ago
Hi Pavee,
Hope I can get your support once again!
How many I2C and SPI we can use in Intel stratix 10 FPGA, is there any limitation?
If we use one spi(MISO,MOSI,CLK) with 6 chip select pins it will act as single SPI only rite?
Thanks & regards,
Aravind D
