jasmel
3 years agoIntel MAX 10 FPGA doesn't support LVTTL at 3.3V with a VOL (max)= 0.40V??
Hello We would like to use the Intel MAX 10 FPGA to drive a 3.3V LVTTL as a JESD8-B. But the datasheet doesn't show that compatibility: VOL(max) = 0.45V, which do NOT follow the JESD8-B requirement...
Mengzhe
3 years agoHi,
Considering your design need to support Jedec JESD8-B or C, I think whether 0.45 V of VOLmax works depends on the opposite end.
If the other end supports LVTTL 3.3V, refer to JESD8-B/C, VILmax is 0.8 V, which is higher than 0.45 V.
To make sure your design works, you can run simulation to check if VIL meets VILmax.
Mengzhe
