LakshmiPriya
4 years agoIntel Cyclone 10 LP FPGA DATA0 and DCLK waveforms
What is the expected waveform on DCLK and DATA0. I am seeing something as in the attached files. The waveform looks different for the first few cycles and changes in voltage levels after that. ...
- 4 years ago
particularly the DCLK waveform doesn't look acceptable to me, the slow risetime is at risk to cause double clock edges at the receiver.
I guess you are performing PS configuration with open drain drivers, e.g. generated by a x51 processor. You should add pull-up resistors to the DCLK and DATA0 lines, or configure push-pull drivers if possible.P.S., please use compressed file format, .jpg or png if you want to post graphics.
Frank
AqidAyman_Altera
4 years agoHello Priya,
Does the solution provided solved your issue?
LakshmiPriya
4 years agoYes, I disabled the open drain drive and it looks good now.
