mark_lee
5 years agoIntel® L- and H-tile Avalon® Streaming and Single Root I/O Virtualization (SR-IOV) IP for PCI Expres
Hi Team
I try to generate SR-IOV example refer to the "Intel® L- and H-tile Avalon® Streaming and Single Root I/O Virtualization (SR-IOV) IP for PCI Express* User Guide " to running on the...
KhaiChein_Y_Intel
5 years agoHi,
I tried to create an example design using the settings that you have provided and keep others as default. The design example generation is successful.
May I know which software edition / version you are using? Can you use the latest version?
KhaiY
mark_lee
5 years agoHi KhaiChein
I use the Quartus Prime Pro 21.1
Does your example select the device 1SG280LU2F50E2VG ? and enable the SR-IOV?
