15 years agoIntegrating a custom component in SOPC [+IRQ]
Hello i made a custom component and integrated it on SOPC, my problem is the IRQ signal... i am using Linux in my NIOS2 and i need to make a device driver to control my custom component, however i h...
14 years agoThis is the read signal, and I'm using the nomenclature defined by Altera in the sopc manual (http://www.altera.com/literature/ug/ug_sopc_builder.pdf) (page 6-4). The only exception is the signal ConfigReadData which is connected to avs_Conf_ReadData outside the process.
Yes you need to keep IRQ on until the ISR routine treats the interrupt and clears it. With this architecture the IRQ signal will stay to 1 until the StatusRegister vector is cleared by software.
