21 years ago
Integrate the Opencores's I2C ip into SOPC
Hello:
I gathered 2 messages about how to integrate Opencores's I2C IP into SOPC.
And I just have got it work by following these instructions below. But one note
is that you can not just include the header file "oc_i2c_master.h" directly.
Please refer to Altera's application note "AN333" to wirte your own header file.
you can easily connect the I2C Wishbone core to the NIOS processor
1. Within SOPC builder, generate interface to user logic.
2. Select bus interface type: avalon register slave.
3. Add "i2c_master_top.v" design file.
4. Read port list from file.
5. Connect the signals as follow:
wb_adr_i <=> address
wb_dat_i <=> writedata
wb_dat_o <=> readdata
wb_we_i <=> write
wb_stb_i <=> chipselect
wb_cyc_i <=> chipselect
wb_inta_o <=> irq
wb_clk_i <=> clk
wb_ack_o <=> waitrequest_n
wb_rst_i <=> always0
arst_i <=> reset_n
scl_pad_i <=> export
scl_pad_o <=> export
scl_padoen_o <=> export
sda_pad_i <=> export
sda_pad_o <=> export
sda_padoen_o <=> export
6. Under timing tab, leave the setup, wait and hold settings at 0 cycles.
You can now access the I2C core via included "oc_i2c_master.h".
Original message is written by "Guido Kuhlmann" from the Opencores forum.
reference from: (http://www.opencores.org/forums.cgi/cores/2004/04/000609)
If you have integrated the I2C IP from Opencores into your system correctly there are only some more steps to bring it to work.
1. Insert -> Symbol ...
2. 2x primitives -> buffer -> tri
3. 2x primitives -> logic -> not
4. 2x primitives -> pin -> bidir
5. connect "scl_padoen_o" and "sda_padoen_o" to the input of the "not"-logics
6. connect "scl_pad_o" and "sda_pad_o" to the input of the "tri"-buffers
7. connect the output of the "not"-logics to the corresponding output-enables of the "tri"-buffers
8. name the output of the "tri"-buffers "i2c_scl" and "i2c_sda"
9. connect "i2c_scl" and "i2c_sda" to the corresponding inputs of the I2C IP
10. connect "i2c_scl" and "i2c_sda" to "bidir"-pins
That&#39;s it!
Original message is written by "niosIIuser" from the Nios forum.
reference from : (here (http://www.niosforum.com/forum/index.php?act=st&f=2&t=590&hl=opencore))
    --- Quote Start ---
    originally posted by tonnoplast@Jan 26 2007, 05:32 AM
    hi. should you give the open cores i2c please?
    and where is possible to find the code on c language for that? i tried the one on portable reference platform but it&#39;s not right.
    many thanks
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=20882)
    --- quote end ---
    --- Quote End ---
    I think using a hardware i2c core is over-killed to the simple problem. You can use pio to access i2c with a simple software approach. You can look at the i2c bus or chips spec. There are bitbanging pio drivers on Linux. Most PC motherboards use pio to access i2c/smbus, too.
    Hi.
    So you sugggest me to use a PIO for interfacing the couple of I2C\SCCB wires instead creating a HDL block? Do you mean that? Obviously i have to create drivers for I2C registers.
    I tried to use,as i said you, Port Ref Plat opencore i2c master and it doesn&#39;t function.Further i tried 3 different I2C software version whith that and again it didin&#39;t function. Probably you&#39;re right.
    Many thanks.
    Yes, I suggest using GPIO and software instead of hardware. Most i2c tasks are only initialization. They are not speed or performance critical.
    You will need to use a osc scope or siganl tap to monitor your io pins. Check pins toggles and senses. You may find a lot of software i2c drivers, some are for 8051. Once you understand the timing, you can make one easily.
    Many thanks hippo.
    At first,what&#39;s a GPIO?
    In my case,i must create a software interface for communicating with an Omnivision Camera(OV6620) which uses not just I2C but SCCB.I read that this difference it&#39;s only for respecting Philips&#39;s"copyright" . Do you know something about that? Are some radical differences between these interfaces or not?
    I&#39;m a beginner with Nios II and i thought that a software for an interface,for example for SCCB, was "global" for every kind of SCCB devices. Would possible to use ready made software? Can you help me ?
    Thanks again.
    Hi again hippo.
    if you can, please answer this question too.
    Always about PIO, i&#39;d like to know if i must edit altera_avalon_pio_regs.h. for adding SCCB\I2C registers. In some way i have to add these registers,am i wrong? Doing that, every PIOs i&#39;m using will have this new build? In other way how to access these registers and create this interface?
    Many thanks again
    OV&#39;s SCCB is I2C. GPIO is general prupose PIO. I think there are a lot of things you need to learn. FIrst you should study some PIO exercises, such as LED, button switch etc. Next you can find some application note on I2C from www.nxp.com. Then you can build your own I2C interface routines. Get some reading about interface and embeded programming books. You&#39;d learn from the bottom up.
    Sorry, I cannot help you step by step. I posted a i2c-gpio driver for uClinux, but I don&#39;t know if it help.
