21 years agoIntegrate the Opencores's I2C ip into SOPC
Hello: I gathered 2 messages about how to integrate Opencores's I2C IP into SOPC. And I just have got it work by following these instructions below. But one note is that you can not ju...
21 years agoHi:
I have designed a IPcore which is belown: library ieee; use ieee.std_logic_1164.all; entity ad574 is port(D :IN STD_LOGIC_VECTOR(15 DOWNTO 0); address: in std_logic_vector(1 downto 0); CLK ,STATUS,read: IN STD_LOGIC;--״̬»úʱÖÓCLK£¬AD574״̬ÐźÅSTATUS byteenable: in std_logic_vector(3 downto 0); chipselect: in std_logic; CE,CS,A0,RC,K12X8: OUT STD_LOGIC; --AD574¿ØÖÆÐźŠQ : out STD_LOGIC_VECTOR(31 DOWNTO 0)); end ad574; architecture behav of ad574 is type state is (st0, st1, st2, st3,st4); signal current_state,next_state :state:=st0; signal data_reg_select: std_logic; signal control_reg_select: std_logic; SIGNAL data_reg : STD_LOGIC_VECTOR(31 DOWNTO 0); SIGNAL lock: STD_LOGIC; begin K12X8 <= '1'; process(address,chipselect) begin data_reg_select<='0'; control_reg_select<='0'; if chipselect='1' then case address is when "00" => data_reg_select<='1'; when "01" => control_reg_select<='1'; when others => null; end case; end if; end process; process(current_state,status) --»ù±¾ÈÎÎñÉè¼Æ(״̬ÄÚÐźű仯) begin case current_state is when st0 =>CE<='0';CS<='1'; A0<='1';RC<='1';LOCK<='0';next_state <= st1; when st1 =>CE<='1';CS<='0'; A0<='0';RC<='0';LOCK<='0'; next_state <= st2; when st2 =>CE<='1';CS<='0'; A0<='0';RC<='0';LOCK<='0'; IF (STATUS='1') THEN next_state <= st2; ELSE next_state <= st3; END IF ; when st3 =>CE<='1';CS<='0'; A0<='0';RC<='1';LOCK<='0'; next_state <= st4; when st4 =>CE<='1';CS<='0'; A0<='0';RC<='1';LOCK<='1'; next_state <= st0; when others =>CE<='0';CS<='1'; A0<='1';RC<='1';LOCK<='0';next_state <= st0; end case; end process; PROCESS (clk,control_reg_select,chipselect) --¿ØÖƼĴæÆ÷¿ØÖÆ×ª»»¹ý³Ì BEGIN IF ( clk'EVENT AND clk='1') THEN if (control_reg_select and chipselect)='1' then current_state <= next_state; end if; END IF; END PROCESS ; process(lock) --Êý¾Ý¿ØÖƼĴæÆ÷²Ù×÷ BEGIN IF LOCK='1' AND LOCK'EVENT THEN if byteenable(0)='1' then data_reg(7 downto 0)<=d(7 downto 0);end if;data_reg<=d; if byteenable(1)='1' then data_reg(15 downto 8)<=d(15 downto 8);end if; if byteenable(2)='1' then data_reg(23 downto 16)<="00000000";end if; if byteenable(3)='1' then data_reg(31 downto 24)<="00000000";end if; END IF; END PROCESS ; process(read,clk,data_reg_select,chipselect) --NIOS×ÜÏßͨѶ begin if clk'event and clk='1' then if (read and data_reg_select and chipselect)='1' then Q <=data_reg; else Q<=(others=>'Z'); end if; end if ; end process; END behav; now I integerate the IP to sopc , and the base address of the IP is :0x02000008 and the end address is 0x0200000f , the generation of the system is successful . but when I built the software about the system above on the NiosII IDE , but there is error and display that the range of the IP ---ad16bit is out of the range of the address , what is it? while I change the "Q : out STD_LOGIC_VECTOR(31 DOWNTO 0));" to " Q : out STD_LOGIC_VECTOR(15 DOWNTO 0)); " the error is disappeared. why? and how can I write the drivers of the IP core ? who can help me?
