14 years agoInteger problem....
Hello. I made the code below and that is working well. But when I test the code in Model_sim.... I don't know how to increase the input 1 by 1 like 0, 1, 2, 3, 4.... 15.. how can i make the...
14 years agoIt depends of how you write your testbench.
1. You can write a counter in your testbench in VHDL which feeds the input of "adder_integer" 2. You can write a macro macro_adder_integer.do (simple text file) which looks like :
# increase "astring" from 0 to 15
for {set inc 0} {$inc <= 15} {incr inc} {
# generate stimuli
force -freeze sim:/adder_integer/astring 0 10#$inc#
# simulate
run 20 ns;# arbitrary value since you don't have clock in your design (typically 50Mhz)
And then in modelsim prompt, type do macro_adder_integer.do ModelSim Macros are in TCL langage 3. type force -freeze sim:/adder_integer/astring 0 10#0# run 20 ns
force -freeze sim:/adder_integer/astring 0 10#1#
run 20 ns
force -freeze sim:/adder_integer/astring 0 10#15#
run 20 ns :-D
