11 years agoInstantiate System Verilog into a VHDL Testbench
Good Evening, I am currently working on a project for school where we taking the original concepts we learned in VHDL and applying them to build the same components with System Verilog. I alrea...
11 years agoThe answer depends on your simulator features; Modelsim-ASE is a single-language simulator, so it can only simulate VHDL or SystemVerilog, not both at the same time. Modelsim-SE is a mixed-language simulator.
If you are using Modelsim-SE, then I would recommend re-using your testbench until your SystemVerilog device-under-test works. I would then recommend re-coding the testbench using SystemVerilog, so that you get an idea how to code a SystemVerilog testbench. Cheers, Dave
