12 years agoInstallation DE1 Board on Windows Xp
Hello to everyone, I've got some problem to install the DE1 Board on Windows Xp. I bought two weeks ago from the site Altera the Cyclone II starter kit that contains Quartus II, other util...
12 years agoHi Michele,
For others reading this thread. It appears that the "Terasic DE1" board http://www.terasic.com.tw/cgi-bin/page/archive.pl?no=83 is also sold as the "Altera Cyclone II Starter Kit" http://www.altera.com/products/devkits/altera/kit-cyc2-2c20n.html According to the schematic: http://www.altera.com/products/devkits/altera/documents/cy2_fpga_starter_board_schematic.pdf The board contains a USB-Blaster, so you can simply install the drivers located in the directory you referred to. I have had success using VirtualBox with Windows XP hosts and Linux hosts, but had trouble with Windows 7 (it would not release the USB-Blaster to the VM). I have not tried with a MAC, but if it allows the VM to capture the USB-Blaster interface, it should work fine. What happened that you could not install the Windows driver for the USB-Blaster? (Which version of Windows is in the VM?) Cheers, Dave
