15 years ago
Install QuartusII 10.1 to Ubuntu 10.04 error!
Hi :
When I install QuartusII 10.1 on Ubuntu 10.04,
I find those error message.
Can you help me!
thansk..............
joe@joe-ubuntu-10:~$ bash ./10.1_quartus_free_linux.sh
log :
:command not find us_free_linux.sh: line 3:
:command not find us_free_linux.sh: line 9:
:command not find us_free_linux.sh: line 16:
./10.1_quartus_free_linux.sh: line 20: syntax error near unexpected token `elif'
'/10.1_quartus_free_linux.sh: line 20: `elif test -x /usr/ucb/echo; then
    --- Quote Start ---
    i installed it, but i dont know how to run, does any one have a idea?
    --- Quote End ---
    1. sudo gedit /etc/profile
    2. Add this setting in the file end.
    SOPC_KIT_NIOS2=/home/XXX/altera/10.1/nios2eds
    SOPC_BUILDER_PATH=/home/XXX/altera/10.1/nios2eds
    QUARTUS_ROOTDIR=/home/XXX/altera/10.1/quartus PATH=$PATH:/home/XXX/altera/10.1/quartus/bin:/home/XXX/altera/10.1/nios2eds/bin:/home/XXX/altera/10.1/quartus/linux
    PATH=$PATH:/home/XXX/altera/10.1/modelsim_ae/linuxaloem:/home/XXX/altera/10.1/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin
    LD_LIBRARY_PATH=/lib:/usr/lib:/home/XXX/altera/10.1/linux
    unset GCC_EXEC_PREFIX
    export LM_LICENSE_FILE QUARTUS_ROOTDIR SOPC_KIT_NIOS2 SOPC_BUILDER_PATH
    export PATH LD_LIBRARY_PATH QUARTUS_64BIT
    /* XXX is your name */
    3. reboot your system
    4. Type quartus in command line.
    There is a same problem I met, is there other meathod? Thanks a lot!
    Try the following:
    sudo rm /bin/sh
    sudo ln -s /bin/bash /bin/sh
    <install the software>
    Works for me.
    Ben
