16 years agoinput to IIR filter in Verilog
Just a quick question regarding implementing an IIR filter in Verilog... At the moment, I am using the Wolfson ADC on the DE2-70 to convert analogue sound input from Line In to digital bits - t...
16 years agoThanks for both of your replies! Cleared a few things up! :)
I really should explain what I'm trying to do: All I want to do is implement a simple low-pass filter to attenuate all harmonics (except the 1st - the fundamental) from an guitar audio signal when a string is plucked - i.e. I'm making a digital guitar tuner. I've designed all the other components of the circuit and am now just trying to get the filter working. A low order IIR low-pass should be fine and shouldn't be too hard to implement... I'm just trying to figure out what to do with the fractions! For example:module test_filter(clk,filter_in,filter_out);
parameter W=7; // bit width - 1
parameter signed a=0.7;
input clk;
input signed filter_in;
output signed filter_out;
reg signed x,y;
initial
begin
x=0;
y=0;
end
always@(posedge clk)
begin
x <= filter_in;
y <= (1-a)*x + a*y;
end
assign filter_out=y;
endmodule // test_filter This is just a test IIR filter I wrote - my question is: How would Verilog treat the 0.7 in the above code? Would the value of y be rounded? Do I need to add extra code if I want to multiply by fractions? (Also, my output from the ADC is now 8-bits (two's complement)! ;)) Cheers, Nick
