15 years agoInput pins are driven down
Hello, I wish everyone have happy new year. In my case, it's not. I have connected input pins of CPLD(MAX II, EPM570C5N) and CMOS image sensor output pins. But, there are a problem with the...
15 years agoOK,
I will double and triple check for it immediately, but I had set unused pins as input tri-stated with weak pull-up pin, but the problem occurred. I have no idea why the pin is driven down. If my config is wrong, the pin should be weak pulled-up. Thanks a lot!
