15 years agoInput pins are driven down
Hello, I wish everyone have happy new year. In my case, it's not. I have connected input pins of CPLD(MAX II, EPM570C5N) and CMOS image sensor output pins. But, there are a problem with the...
15 years ago --- Quote Start --- The programming mode is JTAG, and Quartus II version is 10.0. My USB-Blaster is from terasic. --- Quote End --- Hi, are you sure that the programming is succesful ? Have a look into the <project_name>.pin file and double check your pin assignments. Quartus has a default setting for unused pins, which is "Output driven ground". You should change the setting to " As tri-stated input with weak-pull up" and run a new compilation. You can change the setting by: Assignments -> Device -> Device and pin options -> unused pins Kind regards GPK
