16 years agoInput pin not found using get_ports command
Hello All, Here is my problem. I am trying to constrain one of my input clock ports (pll_1705_mclk) for timing analysis using Timequest but when i use the "get_ports" command i get this error ...
16 years agoHello Rysc,
I was able to solve the problem using your advice. You were right. I did not have an output pin connected to my logic causing registers to be synthesized away. Thanks for all the help!
