16 years agoInput pin not found using get_ports command
Hello All, Here is my problem. I am trying to constrain one of my input clock ports (pll_1705_mclk) for timing analysis using Timequest but when i use the "get_ports" command i get this error ...
16 years agoPlease elaborate on what you mean when you say "synthesized out". How would someone go about resolving that type of problem?
The capitalization on the pin name matches what I've used.
