16 years agoInput pin not found using get_ports command
Hello All, Here is my problem. I am trying to constrain one of my input clock ports (pll_1705_mclk) for timing analysis using Timequest but when i use the "get_ports" command i get this error ...
16 years agoDoes 77 seem right?
One of two things is happening, either the pin doesn't exist(TQ is case-sensitive, so make sure you have that correct). I'm guessing you're sure about the pin name, so the other option is that it got synthesized out. Go to the Technology View and find that input and see if it feeds the clock ports of registers. If it does, it should work.
