16 years agoInput pin not found using get_ports command
Hello All, Here is my problem. I am trying to constrain one of my input clock ports (pll_1705_mclk) for timing analysis using Timequest but when i use the "get_ports" command i get this error ...
16 years agoI've run the fitter and under Resource Usage Summary I am seeing the following information:
Total registers: 77 / 34,134 (<1%) Dedicated logic registers: 77 / 33,216 (<1%) I/O registers: 0 / 918 (0%) My apologies, I am new to Quartus II, is this the information you were looking for? I have also attached the warnings and messages I recieved while running the fitter.
