16 years agoInout questions in testbench
Hi to all :) after doing a certain number of exercizes, about a PWM and an Encoder, I'm doing the first example of a simple PLD. In this example, I use two bus from a DSP: an address bus, and a da...
16 years agook I have another question on this issue.
now it works, but if I write: tdata_dsp <= (others => 'Z'); modelsim thinks that it's like I force tdata_dsp to Z. So, when I enable the writing on the bus it writes, but when I remove the enable, tdat_dsp returns Z... so it's like tdata_dsp is always a input, except when I enable the write... I would like that when I enable the write, tdata_dsp changes its status to an output, until it will return an input (if this happens). Anyway, my doubt is: is this a problem of the testbench, or I will see a similar behaviour even in real?
