Abraham
5 years agoInformation in the number of LDPC cores and Harq cores fot Intel PAC N3000
Hi Team,
I had a doubt. What is the number of LDPC cores and Harq cores for Intel PAC N3000 design as I looked into your datasheet and was not able to get proper info?
Thanks and Regards:
Abrah...
CheepinC_altera
5 years agoHi,
Thanks for your update. As I looked at the document link you provided, it is the A10 device datasheet. To ensure we are on the same page, just to check with you on the following:
1. Just to check with you if you would like to inquire how many LDPC IP instance that can be fit into a specific A10 device?
2. If yes, for your information, LDPC IP is a soft core. The max instances would depend on the resources available in a specific device. You may refer to the 5G LDPC Intel® FPGA IP User Guide for the estimated resource utilization for the LDPC IP.
3. Please let me know if you are referring to the number of LDPC cores used in the FEC vRAN solution on N3000 card.
