16 years agoinformation about the Cyclone IV E
I am trying to use the Cyclone IV EP4CE115 to interface DDR2 SDRAM memory. First of all, I would like to know if you can use every type and size of DDR2 SDRAM memory (1G, 2G, 4G) with the Cyclone IV E ? Second of all, I would like to know the maximum number of DDR2 SDRAM memories you can use with one Cyclone IV E (780 pins package) and with which width of Data Bus support ? Thanks for all.1 Reply
The depth of the memory only results in more address pins. The number of interfaces depends on a bunch of things. There is a guide for this in the External Memory handbook but you should also use quartus to confirm your pin out.
