9 years agoInferred RAM Coding
How can we infer the following memory module as RAM instead of register array ?
https://github.com/promach/internal_logic_analyzer/blob/master/rtl/memory_block.v I have tried to modify, but some inevitable warnings are shown. http://quartushelp.altera.com/14.1/mergedprojects/msgs/msgs/wtdb_analyze_comb_latches.htm (http://quartushelp.altera.com/14.1/mergedprojects/msgs/msgs/wtdb_analyze_comb_latches.htm)
`include "define.v"
module memory_block (clk, write_enable, waddr, raddr, data_write, data_read);
input clk, write_enable;
input waddr;
input raddr;
input data_write; // data to be written into memory
output reg data_read; // data read out from memory
reg memory ;
always @(*) begin
if (write_enable)
memory = data_write;
end
always @(*) begin
if (!write_enable)
data_read = memory;
end
endmodule https://alteraforum.com/forum/attachment.php?attachmentid=14134&stc=12 Replies
Thanks. I could now infer RAM with https://github.com/promach/internal_logic_analyzer/blob/master/rtl/memory_block.v by using larger MEMORY_SIZE.
Probably start by using posedge clk instead of * in the always blocks.
