16 years agoinfer true dual port asynchronous ram
hallo everyone, i need a true dual port asynchronous ram for my selfmade soft-core project. to be hardware independent i try to infer the ram-block from vhdl-code. this is my code: ...
16 years ago --- Quote Start --- hallo everyone, i need a true dual port asynchronous ram for my selfmade soft-core project. to be hardware independent i try to infer the ram-block from vhdl-code. this is my code:
-- Dual-Port Block RAM with Two Write Ports
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
entity TDPR is
generic( width : natural := 16;
depth : natural := 6);
port ( clka : in std_logic;
clkb : in std_logic;
ena : in std_logic;
enb : in std_logic;
wea : in std_logic;
web : in std_logic;
rsta : in std_logic;
rstb : in std_logic;
addra : in std_logic_vector(depth-1 downto 0);
addrb : in std_logic_vector(depth-1 downto 0);
dia : in std_logic_vector(width-1 downto 0);
dib : in std_logic_vector(width-1 downto 0);
doa : out std_logic_vector(width-1 downto 0);
dob : out std_logic_vector(width-1 downto 0));
end TDPR;
architecture syn of TDPR is
type ram_type is array ((2**depth)-1 downto 0) of std_logic_vector(width-1 downto 0);
shared variable RAM : ram_type;
begin
process(CLKA)
begin
if CLKA'event and CLKA = '1' then
if ENA = '1' then
if WEA = '1' then
RAM(conv_integer(ADDRA)) := DIA;
end if;
if rsta = '1' then -- optional reset
doa <= (others => '0');
else
doa <= ram(conv_integer(addra)) ;
end if;
end if;
end if;
end process;
process (CLKB)
begin
if CLKB'event and CLKB = '1' then
if ENB = '1' then
if WEB = '1' then
RAM(conv_integer(ADDRB)) := DIB;
end if;
if rstb = '1' then -- optional reset
dob <= (others => '0');
else
dob <= ram(conv_integer(addrb)) ;
end if;
end if;
end if;
end process;
end syn;xilinx ise infers the correct block structure. but quartus gives an error message: Info: Found 1 instances of uninferred RAM logic Info: RAM logic "TDPR:inst|RAM" is uninferred due to asynchronous read logic Error: Cannot synthesize dual-port RAM logic "TDPR:inst|RAM" is there any possibility to use an true dual port asynchronous ram in vhdl code. (i'm using quartus 9.0sp2) with best regards erik_dl --- Quote End --- Hi, your reset and enable functions could not implemented with Altera Rams. This causes that the RAM is not inferred. The info is a little bit misleading. That means that Quartus could not use the internal RAM for implementation. The only way now for Quartus to implement a RAM are register, which don't have a dual input. That's why you get the error message. If you remove the reset and enable the RAM should be inferred, but that is not what you want ??? Kind regards GPK
