14 years agoincrimental compilation
Greetings, After adjusting one small detail in the signal tap files I have to re-compile the entire design. Is there a way to run all the signal taps, adjust a small parameter and only compile...
14 years agoGo to Assignments -> Design Partition Window and set the Top partition to Post-Fit. In essence, Signal Tap is another partition in the design, so when the top is post-fit, only SignalTap will be resynthesized, placed and routed.
