15 years agoIncrementing loop index in vhdl generate statement
I am working on an HDL for an Altera design. I came a situation where i want to increment vhdl generate loop index by 2. An example is show below, LABEL: for i in 1 to CNTR_WIDTH -1 generate REG1(i) <= ORG_REG(i)(1 downto 0); REG1(i+1) <= ORG_REG(i)(3 downto 2); end generate; I want the generate loop i variable index proceeds like 0,2,4,6 upto the defined range. Please help me how to do this in vhdl? Regards, Jaseel3 Replies
--- Quote Start --- Hi Jaseel I'd have suggested the same as Tricky... but he was faster in replying. If you don't like the i*2 solution you can use a while loop instead of for, so you can increment what you want. --- Quote End --- you cant use while loops for a generate statement - Altera_Forum
Hi Jaseel
I'd have suggested the same as Tricky... but he was faster in replying. If you don't like the i*2 solution you can use a while loop instead of for, so you can increment what you want. - Altera_Forum
just multiply i by 2
REG1(i*2) <= ORG_REG(i*2)(1 downto 0); REG1(i*2 +1) <= ORG_REG(i*2)(3 downto 2);
