14 years agoIn altera Transceiver, why some protocols need rate match fifo, some don't need?
Hi, May i know in altera Transceiver, why some protocols need rate match fifo, some don't need? What is the reason behind?
14 years agoYou can use SRIO to transmit among different boards... as long as the boards have a common clock reference.
It needs to be the same source, crystal, but you can distribute the clock among multiple boards using cables, backplanes, whatever. Ie, SRIO is used in ATCA/µTCA crates, but there's a reference clock distributed by the crate to the boards. But if you have different oscillators, then it's a no-go. You need another protocol which is elastic.
