14 years agoIn altera Transceiver, why some protocols need rate match fifo, some don't need?
Hi, May i know in altera Transceiver, why some protocols need rate match fifo, some don't need? What is the reason behind?
14 years agoHi rbugalho,
you mentioned that, --- Quote Start --- In some applications (ie, SRIO) it's mandatory that all endpoints trace their reference clocks back to the same source (same crystal). --- Quote End --- Can i say that, SRIO only can transmit data within the same board? It is impossible to transmit data from board 1 to board 2, because definitely both boards will use different on board oscillator or crstal already. Am i right?
