15 years agoImplementing FFT with NIOS
Greetings,
I am implementing a design that requires a 16384-point FFT, with 16-bit precision. In an attempt to get this design working, I first started with a 1024 FFT, and got it working perfectly. However, when I scaled it up to 16384, I ran into some issues because the SGDMA interface is limited to 64-bits; but my FFT's output was 68-bits (34 for real, and 34 for imaginary). The following lists the design and components that I am using:- FFT
- 16384 Point
- 16-bit precision/twiddle
- 34-bit real output
- 34-bit imaginary output
- Encapsulated inside of a wrapper the a has 4 interfaces
- 1 MM slave
- 1 Avalon streaming sink
- 2 Avalon streaming sources
- 1 for the real output
- 1 for the imaginary output
- NIOS II/f process
- 3 SGDMAs
- 1 to interface with processor for loading input data to the FFT
- 1 to interface with processor for reading real output data (34-bits)
- 1 to interface with processor for reading imaginary output data (34-bits)
- 1 Input RAM
- Loaded through software using SGDMA interface
- (C code -> SGDMA interface(MM to ST) -> RAM )
- 2 Output RAMs
- Loaded with the output from the FFT, via the SGDMA
- (FFT -> SGMA interface(ST to MM) -> RAM)
