14 years agoImpact of the clock rate to the thermal robustness
Hi everyone, Is any one know what is the impact of the clock rate to the thermal robustness? Is lower clock rate meant higher temperature is possible? Thank you for your help :)
14 years agoThere are at least two different aspects of the problem you need to consider: power dissipation and timing.
- higher clock rate means higher switching frequencies, thus greater power dissipation. If your design has overheating problems, then a lower clock rate could indeed improve the situation. - change in temperature will slightly affect timing. If your design has a critical timing, it could fail if the temperature (or supply, or any other parameter) approaches the specified limit. In such cases a lower clock rate could or could not solve the problem. This depends on the reason a path is not meeting timing: as a rule of thumb, if you have critical timing on setup, reducing frequency makes sense; not if you have hold problems.
