14 years agoImage file generation for non-Altera serial configuration devices
I am using AIIGX fpga along with serial configuration device from Micron. We are using AS configuration mode, in relation to this I have following queries, any help on this would be appreciated. 1. Is AIIGX fpga support non-Altera serial configuration devices? 2. If it is possible then how can I generate a bit stream target to non-EPCS part (in my case Micron device, data sheet attached)? 3. Is there any particular care needed on PCB level to handle above scenario? Thanks, R Shaik.2 Replies
Instead of guessing,I suggest to search the forum for M25P32, preferably start reading the newest entry. The question had been definitely answered.
Yea I know this is really disappointing but in AS mode you probably have to go with the Altera serial configuration devices. Maybe it is possible with a third party SPI flash but there is no documentation and support for this. So it is your risk to try it. Check these links: * configuration comparison (http://www.altera.com/support/devices/configuration/cfg-compare.html) * arria ii configuration handbook (http://www.altera.com/literature/hb/arria-ii-gx/aiigx_51009.pdf)
