19 years agoIm curious why
Noone had any advice about running Cyclone II based boards off rechargeable batteries? Is there something I dont know where it's a bad idea?
19 years ago[My opinion] - You should definately use a switching power supply instead of a linear regulator for this battery powered application, even intial builds. Using a linear regulator, you waste the power from the supply voltage down to the regulated voltage. 5V down to 1.2 V puts you in the 25% efficient range. A switcher puts you at the 90% range. Consider an easy to use one such as
http://focus.ti.com/lit/ds/symlink/tps62243.pdf The effect on your battery life will be dramatic.
