14 years agoif statment issue
hello i am a newbie at vhdl as well as say programming. I am facing issue which is very minor for u all to decide consider i have a std_logic_vector 35 bits long and i want to check whether its...
14 years agothe problem is din0'length is 35
35-1 = 34. So you're asking for (34 downto 32), which is 3 bits not 2. Also, you are missing a load of signals from your process sensitivity list. This code will not simulate at all. And why are you not using the clock? This code is going to create latches (which are bad).
