15 years ago
ieee 754 format
sir i want to represnt 0.46 in ieee 754 format,after presenting if i multiply it with decimal like 3 can i get the desired right value in vhdl?i dont want to use fixed_pkg,it was too much combersome,i can't run it.:(
    --- Quote Start ---
    The only way to do floating point is with alteras floating point IP blocks.
    --- Quote End ---
    You could also implement the IEEE-754 arithmetic yourself (which is a considerable amount of work) or obtain IEEE-754 IP from a third party vendor.
    the fixed package is not for floating point numbers. The only way to do floating point is with alteras floating point IP blocks.
