15 years agoieee 754 format
sir i want to represnt 0.46 in ieee 754 format,after presenting if i multiply it with decimal like 3 can i get the desired right value in vhdl?i dont want to use fixed_pkg,it was too much combersome,...
15 years ago --- Quote Start --- The only way to do floating point is with alteras floating point IP blocks. --- Quote End --- You could also implement the IEEE-754 arithmetic yourself (which is a considerable amount of work) or obtain IEEE-754 IP from a third party vendor.
