Bill_A
4 years agoI2C to Avalon-MM Master Bridge
I have used Platform Designer in Quartus Prime Lite 20.1.1 Build 720. This bridge is connected to multiple I2C Master cores. There is no address overlap in Platform Designer. The Master uses 3 byt...
ShengN_altera
4 years agoGlad to hear that your issue has been resolved.
Actually there are two methods to specify default slave:
- <Automatic setting method> Automate default slave insertion to TRUE
- <Manually> Right-click the bar in System Contents of Platform Designer to display and select Default slave
May be you are using second method for MAX 10.
Let me know if you have any further updates or concerns.
Best Regards
Sheng
