16 years agoi2c problem
Hello. I made a i2c to configure in sidetone the audio codec on de2 bord. It seems i may encounter two problems: 1. The Sda line changes the state on the scl='1' insted of scl='0', so the ...
16 years ago --- Quote Start --- The Sda line changes the state on the scl='1' --- Quote End --- You mean, your code operates it this way? --- Quote Start --- The sda is pulled up to vdd. --- Quote End --- That's how I2C works. Bus drivers should operate as open drain, which is simple with a FPGA I/O pin. --- Quote Start --- Does altera provide any solutions for these problems? --- Quote End --- DE2 is a Terasic product, shipped with Verilog demonstration code. It's basically working, but not particularly instructive. The I2C related code, as far as I'm aware of is pretty basic and can be converted to VHDL without deep Verilog knowledge (in my opinion). Others have probably written own I2C code from the scratch based on the NXP specification or used IP from the internet.
