17 years agoI2C on EPM570M100
Hi all, I am trying to implement the I2C protocol (master side) on an EPM570 CPLD. I am new to VHDL so I am having trouble finding the errors of my code. Basically the code is working, I can s...
17 years agoHi all,
I managed to implement the protocol. You were right, my problem was with the timing. I did a little trick in order to implement it with only 2 clock phases per bit. I divided the main clock by 2 using the falling edge as a trigger. I used the resulting clock for the SCL line. In another process I've implemented the communication on the SDA line while it used the main clock divided by 2 with its rising edge as a trigger. Thus, all of the protocol's timing requirements were met. It came out a little "ugly" in some places, but it works well. Thanks for all the help.
