17 years agoI2C on EPM570M100
Hi all, I am trying to implement the I2C protocol (master side) on an EPM570 CPLD. I am new to VHDL so I am having trouble finding the errors of my code. Basically the code is working, I can s...
17 years ago@ vernmid
Thanks for the reply. As far as I know, the latching does take place on the rising edge. This is the reason that I am using a 16kHz clock for the communication while the process is triggered by a 32kHz clock - in this case I can change/sample the data line in the middle of the bit, avoiding race (hopefully). During the "write" sequence, I can see both the bits that I transmit and the ACKs from the device with proper timing. The problem is that when I try to read data from the device, it sends something different then defined in its spec, for example the zeroes that I mentioned earlier, which makes me think that I've done something wrong with the read process.
