14 years ago
i2c in sopc builder
Hello all;
I downloaded I2opencores, How do I use?
How can I add it in SOPC builder?
thank you very much.
    I did as you said and it worked.
    but now I have these errors:
    Error: opencores_i2c_0: opencores_i2c_0.avalon_slave_0 must be connected to an Avalon-MM master
    Warning: opencores_i2c: set_interface_property: export_0 Interface (conduit) can not have associatedClock
    Warning: opencores_i2c_0: Interrupt opencores_i2c_0.interrupt_sender sender is not connected to an interrupt receiver
    how can I fix this?
    thanks a lot.
    heh heh,
    you're right, but my English is from google translator!
    I do not know what the reputation button! I'm new, if you explain it to me, surely I'll use it.
    In the meantime, why not work opencores? I copied the entire folder in the path:
    C/altera/10.1/ip/opencores
    Thank you,
    Best Regards.
    Because.
    You're welcome.
    P.S. Please ask properly and fix Your english.
    Hello, I created a folder inside altera/10.1/ip but is seen by SOPC. Why?
    thanks
    Either copy it to altera\11.1\ip\opencores\ (I've created opencores dir by myself) or copy anywhere and add a new search path in sopc builder.
