17 years agoI want to know the max speed of NIOS ii based on cyclone iii EP3C120N780C
I have a DK-DSP-3C120N KIT,the NIOS II clock can not exceed 100mhz.The highest speed of NIOS II /f is now just 100mhz.The C program always dead when the clock exceed 100mhz.I want to working at least...
16 years agoHello,
I am designing an Ethernet connectivity using Cyclone III development board, therefore RGMII is used as an interface between the MAC & PHY. After building the complete system in SOPC builder and then compiling the design, there are a lat of warnings and a critical warning (timing requirement not met). I am trying now to fix the critical warning. In doing so, I started by constraining all paths and I/O ports in the design, the number of warnings decreased, but there is still a critical warning (timing requirement not met). Any advice regarding this issue. Thanks & Regards
