17 years agoI want to know the max speed of NIOS ii based on cyclone iii EP3C120N780C
I have a DK-DSP-3C120N KIT,the NIOS II clock can not exceed 100mhz.The highest speed of NIOS II /f is now just 100mhz.The C program always dead when the clock exceed 100mhz.I want to working at least...
16 years agoYou declare variables using 'set <var name> <value>' but when you use the variable in your script you have to use '$<var name>'
i.e. set Imavariable abc $Imavariable > abc
