17 years agoI want to know the max speed of NIOS ii based on cyclone iii EP3C120N780C
I have a DK-DSP-3C120N KIT,the NIOS II clock can not exceed 100mhz.The highest speed of NIOS II /f is now just 100mhz.The C program always dead when the clock exceed 100mhz.I want to working at least...
16 years agoHello,BadOmen:
Thank you for reply. As your suggestion,I add this code in the .SDC file: set sys_clk inst|the_altmemddr|altmemddr_controller_phy_inst|altmemddr_phy_inst|altmemddr_phy_alt_mem_phy_inst|clk|pll|altpll_component|auto_generated|pll1|clk[0] I'm not sure if it has no syntax error.The TimeQuest still warning like this: 1:Warning: At least one of the filters had some problems and could not be matched. --- Warning: sys_clk could not be matched with a clock. 2:Warning: Ignored assignment: set_input_delay -add_delay -max -clock [get_clocks {sys_clk}] 2.000 [get_ports {reset_n}] --- Warning: Argument -clock is an empty collection 3:Warning: Ignored assignment: set_input_delay -add_delay -min -clock [get_clocks {sys_clk}] 1.000 [get_ports {reset_n}] --- Warning: Argument -clock is an empty collection The long clock name which I got from the clock summary seemed incorrect: inst|the_altmemddr|altmemddr_controller_phy_inst|altmemddr_phy_inst|altmemddr_phy_alt_mem_phy_inst|clk|pll|altpll_component|auto_generated|pll1|clk[0]
