17 years agoI want to know the max speed of NIOS ii based on cyclone iii EP3C120N780C
I have a DK-DSP-3C120N KIT,the NIOS II clock can not exceed 100mhz.The highest speed of NIOS II /f is now just 100mhz.The C program always dead when the clock exceed 100mhz.I want to working at least...
16 years agoDear BadOmen:
For the JTAG Signal Constraints,I've added the following code in my .sdc file:# JTAG Signal Constraints constrain the TCK port create_clock -name tck -period 100.000 [get_ports altera_reserved_tck]# Cut all paths to and from tck set_clock_groups -group [get_clocks tck]# Constrain the TDI port set_input_delay -clock tck 20.000 [get_ports altera_reserved_tdi]# Constrain the TMS port set_input_delay -clock tck 20.000 [get_ports altera_reserved_tms]# Constrain the TDO port set_output_delay -clock tck 20.000 [get_ports altera_reserved_tdo] When I "Read SDC File" in the TimeQuest,It always report "Error Status" in the SDC File List.I found only this sentence cause the error: set_clock_groups -group [get_clocks tck] Why? It seemed has no syntax error. The file status turn to OK when I delete the sentence,but can not constraining the JTAG.
