14 years ago
I want to design FIR and IIR Filters...
which FPGA is the best?
Cyclone
Arria
or
Stratix
    With such a low speed , resource should not be an issue as you can run on 55 x 500 or more and share one multiplier (MAC).
    If you opt for IIR then the phase will suffer (nonlinear).
    --- Quote Start ---
    Read these;
    http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-100paper_hawkins.pdf
    http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-100slides_hawkins.pdf
    http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial.pdf
    There are plenty of cross-references in there for you to look at too.
    --- Quote End ---
    thank you so much for the information
    I´m still reading, there are a lot of interesting things that will be very useful for the filter design
    --- Quote Start ---
    FIR filter design literature gives more exact expressions for the required filter length depending on stop band attenuation and pass and stopp band frequency. Typical relative lengths are considerable larger than L > 1/fc.
    The FIR design chapter of U.Meyer-Baese digital signal processing with fpga gives a brief overview of popular design methods.
    --- Quote End ---
    thanks I will review this
    --- Quote Start ---
    --- Quote End ---
    thanks, I worried about my cyclone II, I have the opportunity to buy another if necessary but I prefer to work with mine
