14 years agoI want to design FIR and IIR Filters...
which FPGA is the best? Cyclone Arria or Stratix
14 years ago --- Quote Start --- At 500 samples per second your FPGA has many many clock cycles to perform calculations. You can use a single multiplier and RAM and implement the FIR. The IIR should be able to be implemented with 2 (Butterworth) or 5 multipliers per second-order-section. You should perform a bit accurate simulation using a FIR/IIR design tool to determine the filter parameters. --- Quote End --- thanks for the advices I think that I need to have my filter design completely ready first, I'm using Matlab for this I was afraid that my desing wouldn't fit in my cyclone II , I need to determinate all parameters first and chose an implementation
