17 years agoI want knowing POF file format structures.
hello, everyone.
I want knowing POF file format structures. I can open a .pof file and program this to the EPCS16 device if i know the length of the header so i can remove it first. The header includes info about Quartus build date/version/device/comment e.t.c The .pof file also includes a signature, but since the useful data only exists until about 1/3 into the file, this signature is also removed when programming.. Does anyone know the .pof file format? I really need to know this: 1. Where is the header-length is specified? 2. What does the different "unknown" bytes in the header (except for the obvious ascii coded strings) specify? My application can also read the contens of the flash and save it to a file. It would be really useful if this could be saved in a .pof valid format, and written back using the quartus programming tool, so: 3. What does the Quartus programming tool look for to determine if the .pof is valid? (checksum? probably some of the info requested in 1, 2?) 4. What does the signature/footer describe? Thanks so much.15 Replies
Compression setting may be different.
Suxilong,
Would you mind posting the EPCS4 data & rbf file? I have some experience reversing this stuff & and I will help if I can... Larry - Altera_Forum
FWIW the crc is CRC-CCITT as used by hdlc.
This means the the calculation can be reduced to:crc = 0xffff; while (p < lim) { crc ^= *p++; t = (crc ^ crc << 4) & 0xff; crc = crc >> 8 ^ t << 8 ^ t << 3 ^ t >> 4; crc ^= 0xffff; - Altera_Forum
--- Quote Start --- this should get you started... fmt_pof.pdf contains info on the .pof file format pofcrc_src_bin.zip contains a windows application(src is in C) I wrote to correct the .pof CRC. good luck. --- Quote End --- Thanks a lot. You greatest man ever. Go for beer if you visit Saint-Petersburg someday. - Altera_Forum
fmt_pof.pdf is an excerpt of DataIO UniFam Translation File Formats Page 10 @ http://ftp.dataio.com/main/manuals/unifam/translation%20formats.pdf
