17 years agoI need yor hlp.....
Hello!!!
this code for the first component of QPSK modulator(serial to parellel converter.the second compnent is NRZ,i need to know how can I integrate the output of serial to parellel with NRZ. this code of(s to p): library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity FFF is Port ( S : out bit; R : in bit; clk : in bit; P : in bit_vector (7 downto 0)); end FFF; architecture Behavioral of FFF is --signal shift_reg : std_logic_vector(7 downto 0); begin process (clk,R,P) variable shift_reg : bit_VECTOR(7 downto 0); begin if R ='0' then shift_reg(7 downto 0) := P(7 downto 0); elsif (clk'event and clk='1') then S <= shift_reg(7); --shift_reg (7 downto 1) := shift_reg(6 downto 0); shift_reg (7 downto 0) := ( shift_reg (6 downto 0) & shift_reg(7) ); end if; end process; end Behavioral; this code for NRZ:----------------UNIPOLAR TO BIPOLAR---------------[LOGIC 0=-1, LOGIC 1=1]------- LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.std_logic_unsigned.all; USE ieee.std_logic_signed.all; USE ieee.numeric_std.all; ------------------defines two types: unsigned and signed ENTITY unipolar_bipolar IS PORT( in_i,in_q : IN std_logic_vector (3 downto 0); -------4 bit------- bI,bQ: OUT std_logic_vector (3 downto 0) -------4 bit------- ); END unipolar_bipolar ; ARCHITECTURE beh OF unipolar_bipolar IS signal p: integer;------------out signal k: integer;-------------in signal n: std_logic_vector(3 downto 0);--------------out(final) signal i:integer; -----------------------for loop 0 until 3 (4 bit)----------- begin for i=> '0'; LOOP i=n; when in_i(n)=> k & in_q(n)=> k then case k is when k ='0' then -----must invert to signed value---[-1] p <= '1'; -------in std_logic out_q(n)<= conv_integer(p); out_i(n) <= conv_integer(p); --------convert into integer(signed) end case; case k is when k ='1' then-----must invert to unsigned value--[1] p <= '1'; -------in std_logic out_q(n)<= conv_integer('0'& p); out_i(n) <= conv_integer('0' & p); --------convert into integer(unsigned) end case; n = i+1; when n='3' loop; end LOOP; end beh; I hope help me as soon as possible:confused: :confused: :confused:No RepliesBe the first to reply
