8 years agoI Have imported the correct libraries and still get an error.
So i have this little piece of a datapath entity.
library ieee; use ieee.std_logic_1164.all; use IEEE.std_logic_arith.all; use IEEE.std_logic_unsigned.all; entity Datapath is port ( R1, R2, E1, E2, E3, E4, E5: in std_logic; CLOCK_50: in std_logic; SEQIN,SQR: in std_logic_vector (9 downto 0); SW_erro, end_game, end_time, end_round: out std_logic; Smt: out std_logic_vector(3 downto 0); SmN: out std_logic_vector (3 downto 0); result: out std_logic_vector (7 downto 0) ); end Datapath; architecture arqdtp of Datapath is signal SmSwitches: std_logic_vector(2 downto 0); signal SeqRom, SeqSw: std_logic_vector(9 downto 0); signal SmT_in, SmN_in: std_logic_vector(3 downto 0); signal C: std_logic; begin -- Registrador e Somador: P1: process(CLOCK_50,R1) begin if (R1 = '1') then -- R1 Time reset Smt_in<= "0101"; elsif (CLOCK_50'event AND CLOCK_50 = '1') then if (E1 = '1') then Smt_in <= Smt_in - '1'; SmT <= SmT_in; end if; end if; end process; P2: process(CLOCK_50,R2) begin if (R2 = '1') then -- R2 reset Next round SmN_in<= "0000"; -- Soma Next round elsif (CLOCK_50'event AND CLOCK_50 = '1') then if (E3 = '1') then SmN_in <= SmN_in + '1'; SmN <= SmN_in; end if; end if; end process; -- Comparador: end_time <= '1' when (Smt_in = "0000") else '0'; end_round <= '1' when (SmN_in = "1010") else '0'; end_game <= '1' when (SeqSw = SeqRom)else '0'; SmSwitches <= (SEQIN(1)+SEQIN(2)+SEQIN(3)+SEQIN(4)+SEQIN(5)+SEQIN(6)+SEQIN(7)+SEQIN(8)+SEQIN(9)); -- For some reason it gives me the error here. SW_erro<= '1' when (SmSwitches > "0100") else '0'; -- Sequencia secreta P3: process(CLOCK_50,E4) begin if (E4 = '1') then -- Sequencia do Jogo reset SeqSw<= "0000000000"; -- Sequencia 4 bits elsif (CLOCK_50'event AND CLOCK_50 = '1' and E2 = '1') then SeqRom <= SEQR; end if; end process; -- Sequencia escolhida P4: process(E5) begin if (E5 = '1') then -- Sequencia Escolhida reset SeqRom<= "0000000000"; -- Sequencia 10 bits C <= end_game; result <= ("16" * C) + ("10" - SmN); end if; end process; end arqdtp; and i am still getting: Error (10327): VHDL error at Datapath.vhd(53): can't determine definition of operator ""+"" -- found 0 possible definitions Can anyone please help me? It is urgent.2 Replies
The SmSwitches signal is declared as a 3-bit vector. How are you trying to add or concatenate 9 bits into a 3-bit vector ? If you're trying to concatenate bits to form a 3-bit signal then you need to use the '&' operator.
Go through the previous thread. http://www.alteraforum.com/forum/showthread.php?t=1891 1. Adding 9 1-bit data (SEQIN) and displaying the result in a 3-bit (SmSwitches), You required to use VHDL concatenation operator (&) is used to put a 0 in front/back of each of the 9 1-bit numbers before adding them.
2. You can use numeric and unsigned library. Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)SmSwitches <= ("00"& SEQIN(1)+"00"& SEQIN(2)+"00"&SEQIN(3)+"00"&SEQIN(4)+"00"&SEQIN(5)+"00"&SEQIN(6)+"00"&SEQIN(7)+"00"&SEQIN(8)+"00"&SEQIN(9));
