14 years agoI cant work this out!
This is to adjust volume of incoming audio samples by just multiplying by a constant value (SW). I wanted to be able to control the volume value with the switches on the DE2 but i get no sound at all...
14 years agoOk i got it working. It was something i had no idea would make a difference but thought i'd try it. I hope you might be able to explain or help me understand why this makes a difference
I added what a few other designs i've seen call a pipeline buffer- code below From looking at this, it just seems like the audio samples are being synced upto the system clock edge but i dont understand why that is necessary.library IEEE;
use IEEE.std_logic_1164.all;
entity pipeline_buffer is
port (
clk: in std_logic;
lrclk: in std_logic;
reset: in std_logic;
-- data
sample_in_left: in std_logic_vector(15 downto 0);
sample_out_left: out std_logic_vector(15 downto 0);
sample_in_right: in std_logic_vector(15 downto 0);
sample_out_right: out std_logic_vector(15 downto 0)
end entity pipeline_buffer;
architecture beh of pipeline_buffer is
signal last_lrclk: std_logic;
begin
process (clk, reset)
begin
if (reset='0') then
sample_out_right <= (others => '0');
sample_out_left <= (others => '0');
elsif rising_edge(clk) then
sample_out_right <= sample_in_right;
sample_out_left <= sample_in_left;
end if;
end process;
end architecture beh;
